'97 saturn sw2 automatic
Old Jun 21, 2016 | 02:37 PM
Tu MadRe's Avatar
Default '97 saturn sw2 automatic
hey I'm new here and I love my new car for $600, 154xxx! '97 saturn sw2 wagon automatic. Anyways I'm having problems since im throwing some code on the ob2 scanner of p0717/16 and I'm hearing my problem is my turbine speed sensor. (i was throwing p0420 but that went away I HOPE). -However I'm trying to place an order to purchase a brand new turbine speed sensor from rock auto and I like to know if I type in turbine speed sensor.. am I buying the correct part? I ALSO poSTED a photo of the part. Thank you
Old Jun 21, 2016 | 10:05 PM
see
P0716 and P0716 - SaturnFans.com Forums
for P0716 /P0717. you may not need to replace it.
IF you do, get the AC Delco or Standard Motor Products
____________
P0420 catalyst below efficiency threshold
If your catcon is gone, this code is not going away on iis own.
Sometimes the rear O2 sensor can get poisoned and cause erroneous readings.
If you choose to do the rear O2, go with the Denso version of the OEM part
Old Jun 22, 2016 | 10:18 AM
Tu MadRe's Avatar
see
____________
hey!!! thank u for letting me know something. however I was following the right and correct information when I cleaned the turbine speed sensor this past Sunday with electrical cleaner spray and after putting everything back together? engine service soon light pops on every 5 seconds laters after i clear the 716/717 code. so I had to ask.. and now you told me the info I wanna hear! I'm not gonna wait anymore or decide to mess with it. every thing under $100 shipped to the HUT! Anyways but you said THE Rear o2 sensor? cause I'll ask for a rear o2 SENSOR when I call up rockAUTO and place my order so I can make sure I'm ordering the acurate correct part.
Thank you so much!!!
Old Sep 4, 2020 | 06:47 AM
Jesse Shaw's Avatar
U have the right part i have the same car as u do i had that problem a about last year as soon as i replaced the bad speed sensor and put a new one in my car was just fine.
so u r good.
Kazbear
Sep 19, 2020 01:16 PM
kensat
Oct 12, 2011 09:21 PM
rickatom
Jul 20, 2007 03:49 PM
osuddeth
Aug 26, 2006 01:05 PM
SL2ofDoom
Aug 11, 2006 10:40 AM
