97 Saturn SL1 175000 Miles AC Problem
Old Jul 21, 2009 | 02:17 PM
kuhlero's Avatar
Default 97 Saturn SL1 175000 Miles AC Problem
So talk about throwing parts at my Saturn:
1) AC stops blowing cold air, recharge with a couple of cans of R134A=Still blowing hot air
2) Replace Compressor with Junk Yard Compressor, evacuate recharge again=Still blowing hot air
3) Replace Air Filter/Drier= evacuate recharge again=Still blowing hot air
4) Blow out lines with compressor, remove expansion valve, and blow out expansion valve resorvoir= evacuate recharge again=Still blowing hot air
Will get readings and post them later when I'm at home...
Any Ideas????????????:ma d:
Old Jul 21, 2009 | 04:46 PM
Yeah -- the pressure readings from the suction and discharge ports of your system should be most enlightening ...
Old Jul 21, 2009 | 09:33 PM
You did all that without even knowing the high and low side readings?
Old Jul 22, 2009 | 08:54 AM
kuhlero's Avatar
Yeah sure did, I know, natural selection comes to mind, lol. Low side extremely high, high side normal, obviously the compressor is shot!!!!!!!
Old Jul 22, 2009 | 11:18 AM
??? Numbers ???
Old Jul 23, 2009 | 07:47 AM
How many pounds of refrigerant does it take to charge the system?
How many pounds of refrigerant do you find in the system when you evacuate?
Old Jul 23, 2009 | 11:49 AM
Twisted Noodle's Avatar
I say take it out. All of it. It adds weight which brings down your ET.
Old Jul 23, 2009 | 08:56 PM
low side high sounds like blockage
DCARNEY51
Jun 18, 2015 02:43 PM
Joe Lukaitis
Apr 28, 2008 03:42 PM
Mootacular
Apr 9, 2008 11:52 AM
M3King
Sep 18, 2007 12:12 PM
