97 dohc 134 code
Old Mar 3, 2010 | 02:09 PM
racerps66's Avatar
Question 97 dohc 134 code
134 code is o2 sensor down stream is inactive.changed out o2 sensor(4-wire)
twice and cat once.still getting about code after about 20-30 minutes of driving.when cold has hard time starting if i dont hold gas pedal down,warmed up is ok.thought injectors might be dirty,have added injector cleaner,have drove about 20 miles or so but no change!
Old Mar 3, 2010 | 10:03 PM
Replace the ECTS sensor, sounds like it's gone bad. While you're at it, replace the connector as well. Use OEM parts - cost a bit more, but they work so much better
Old Mar 5, 2010 | 01:44 PM
racerps66's Avatar
Thanks OceanArcher ,I already tried that yesterday still no change.It also rev's to about 2 grand when shifting from d to park.Once code is thrown does'nt want to idle in drive.
Old Mar 18, 2010 | 10:52 PM
I do believe P0134 is
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
Which is the front O2 sensor pre cat not post cat
It's hard to start cold because the A/F mix is way off,
____
Change Front 02 sensor. Use the Denso part -- the bosch ones and the universals suck in my experience
james clark
Feb 23, 2011 09:24 PM
mikes 1994 z28
Aug 9, 2006 09:08 AM
