97 dohc 134 code
134 code is o2 sensor down stream is inactive.changed out o2 sensor(4-wire)
twice and cat once.still getting about code after about 20-30 minutes of driving.when cold has hard time starting if i dont hold gas pedal down,warmed up is ok.thought injectors might be dirty,have added injector cleaner,have drove about 20 miles or so but no change!
I do believe P0134 is
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
Which is the front O2 sensor pre cat not post cat
It's hard to start cold because the A/F mix is way off,
____
Change Front 02 sensor. Use the Denso part -- the bosch ones and the universals suck in my experience
____
mikes 1994 z28
Aug 9, 2006 09:08 AM
