’96 SL1 idle issue
Old Apr 9, 2008 | 11:48 AM
demope's Avatar
My '96 SL1 has an idle issue maybe one of you have seen before and can help me with. When warm, it idles right at 750 RPM, like at a light or stop sign. Sometimes, it'll flucuate up or down 50 RPM's and then stall. I can restart it, but it takes longer than if I was starting it cold. Any ideas here?? Could it be the idle air control valve??
Thanks!!
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old Apr 13, 2008 | 02:53 PM
97'SL2's Avatar
Im having the same issue!! Have you found out anything or have you fixed
the problem. If you have any advice it would be really appreciated!!
Old Apr 18, 2008 | 06:05 PM
97'SL2's Avatar
hey i got the Sl2 running you might want to take your Idle air control valve
off and clean it out with soon carb cleaner or something of that nature. Also
check for vacuum leks. if that doesn't work do the same thing to the egr
valve and install a new gasket. That should work for you.
Old Apr 21, 2008 | 10:02 AM
demope's Avatar
Will do!! Thanks for the suggestions!
< =text/>
urchinTracker();
Old Apr 21, 2008 | 09:24 PM
jayd9631's Avatar
I have a 96 sl1 also, im almost possitive it hase nothing to do with the air, plus that gets expensive. Try the FUEL FLITER. it runs about $30at kragen. i guarentee you have never changed it, and considering it is a 96' it has been a long time. Try it out let me know,
Lates
Jay
< =text/>
urchinTracker();
shock6906
Apr 9, 2015 07:24 PM
nd48463
Nov 16, 2009 03:12 PM
superspeeder
Jan 19, 2009 10:27 AM
ASKBCG
Sep 21, 2008 12:40 PM
blind527
Nov 22, 2006 09:33 PM
