96 saturn engine into a 94?
Old Oct 16, 2008 | 01:22 PM
Ryan31783's Avatar
I am thinking about buying a 94 4 door saturn with a siezed engine to fix and sell, I was wondering if an engine out of a 96 4 door would bolt up or not? Sorry if this is a pretty vague question, I don''t know the first thing about saturns, all i own is toyota''s
TIA
Ryan
Old Oct 18, 2008 | 10:57 PM
Low Saturn's Avatar
Yes.
Use the 1994''''s original intake manifold, fuel rail, injectors and throttle body. You''''ll also need to drill and tap a hole for the second temperature sensor found on 1991-1995''''s. The neck where the upper radiator connects to the head is a perfect spot.
This is assuming you''re talking about a DOHC (SL2, SC2 or SW2). If its a SOHC, then forget about it.Edited by: Low Saturn
chriswf
Feb 25, 2011 08:39 AM
BamaSl2
Jan 23, 2010 09:56 AM
keithrulz
May 16, 2008 09:43 PM
zodszoo
Mar 17, 2008 11:20 PM
rhaslam
May 1, 2006 12:32 PM
