95SL1 Starting problems
Old Feb 26, 2007 | 09:46 PM
rjohnson's Avatar
I had a problem this afternoon with my 95 SL1.
When I went to start it, it was dead. No sound at all from the starter. The clock on the radio was out, not lights etc. I boosted it with a friend and we got it running. After driving a hundred feet or so it died again. I boosted it a second time and that time when I touched the break pedal the engine cut out. The clock was reset each time I got it started.
When it was dead, the battery had about 11V, while it was running the battery had over 14. No signs of problems up until then. It was no colder than -5C at the time (20F) which is quite warm for what it has been.
It seems to be something electrical, but I don't think it could be the battery because it spontaneously dies when its running, and the last time I had alternator problems, I could tell it was dying by the battery light. Any ideas?
Old Feb 26, 2007 | 10:07 PM
keith's Avatar
The battery has an internal short. The computer hiccups when the
voltage drops too low, that why the engine dies. If you keep
trying to drive it, you can melt the diodes in your alternator.
If you are not convinced, take the battery out and take it to an autoparts store and have them load test it for you.
Old Feb 27, 2007 | 01:00 AM
Battery can no longer hold a charge. Alternator seems to be fine.
wily420
Jan 13, 2008 12:06 PM
nemo
Jan 11, 2008 09:30 AM
dlshoema
Jan 5, 2008 09:13 AM
imaukfan
Sep 24, 2007 03:45 PM
hot2cool
Oct 20, 2005 07:02 PM
