95 sl2 wont start? please help.
Old Jan 12, 2011 | 10:58 PM
Hoffer's Avatar
Default 95 sl2 wont start? please help.
The starter will crank, and it seems like it wants to start, but it never does. I have read through several threads. So i had a few ideas and started with that.
I checked all of the ign fuses. All Good
Then checked the fuel pressure. 40 psi
I checked spark. I replaced 1 coil and the spark plugs corresponding.
Spark is good at both coils. (I am replacing all of the plugs)
So it can't be the CPS.
Should I replace the wires too?
When i try and turn it over and rechecked the plugs they were wet (gas).
What would be the next step. Thank you for your time and answers.
I'm in Mn it is very cold here.
Old Jan 12, 2011 | 11:53 PM
Wintertime in Minnesota is not the time to be working on your car. I sincerely hope you have it in a garage somewhere. Unless you have 100,000 + on the wires, they are probably OK. I would replace the ECTS and its associated connector (about $45 usd for both parts) ... stay warm, and good luck
Old Jan 13, 2011 | 08:01 AM
Not having a problem with my temperature sensors on my 94 since I discovered that there was a service bulletin on them some 10 or so years ago directly relating to false overheat indications and changed replaced them with correct ones, I have not experiance another problem with them. So;
a couple of questions.
Depending on the year of the car (one or two sensors) do they really screw things up so it won't start? To me that is a bit of stretch to buy into but truth is stranger than fiction
and
is there a diagnostic for this. Such as
will the car start if the they are unplugged?
I'd rather have a diagnostic than throw $45.00 at something that won't do anything on a guess.
Enquiring minds would like to know.
Old Jan 13, 2011 | 09:38 AM
Hoffer's Avatar
Thank you for the quick reponse.
Her car is in her garage, which does help a lot. It was sunny yesterday and 20's. Today is not, i will dress warm and take breaks.
I will replace the ect and connector and finish up the other work I have to do. (2 spark plugs recheck the old coil)
Old Jan 17, 2011 | 04:46 PM
Hoffer's Avatar
I got the ECTS replace and it took two times to try and start, but it fired up. Thank you again for the help.
I got a multi meter to check the sensor it was reading 1.640 ohms. This should have been 5600 to 2400 between 50 and 80 degrees but it was super cold so more like 15000 ohms.
Old Jan 17, 2011 | 09:20 PM
UnclJohn ...
The answer is "Yes, it can." In an effort to get both maximum fuel economy and maximum performance, the mixture ratio of the engine is continuously adjusted with respect to the temperature of the engine. The ECTS is your sensor for that measurement .....
Old Jul 24, 2011 | 10:40 AM
saturnchix's Avatar
Default uncle jon ects
hey do u guys know how to replace ects connector....? splicing needing and directions or diagrams to explain how and tools u need?
i think the ects sensor is str8 forward but th e connector seems trickey?
thanks guys!1
Old Jul 24, 2011 | 10:52 AM
the oem (read get from gm dealer) comes with a splice on the two connector wires if I remember correctly. cut n splice
SL2
May 30, 2024 08:34 PM
br4nd0n
Dec 14, 2010 08:22 PM
one54ton
Nov 19, 2010 09:00 AM
rmorgan
Oct 26, 2010 06:40 PM
wizeguy4
Jan 4, 2010 10:35 PM
