94 sl2
Old Aug 27, 2009 | 07:19 PM
Ringo32's Avatar
Default 94 sl2
Hi my wife has a 94 SL2 which has been a great car,over the last few weeks it has developed a problem with the headlights.Sometimes the low beams will not work(on both passenger and driver side lights)but the highbeams will,other times both beams will work which to me is the strange part.Has anyone had this problem before? i know there is a loose conection at the driverside headlamp which effects the park light and signal light on drivers side,when i wiggle the connector both lights will work fine,could this also be the problem with the headlights?
Any help would be great
thanks
Old Aug 30, 2009 | 12:19 AM
saturnsdn's Avatar
Find out whats going on with that loose connection before you get into anything else. may not have anything to do with the problem but who knows. you may also what to check the grounds to the low beams to see if theres a bad connection somewhere
