’94 SL-A/C & Radio went out @ same time
Old Nov 12, 2007 | 09:48 AM
castortroy's Avatar
'94 SL Sedan double over-head cam
A/C and Radio went out at the same time. I've checked the fuses and they're ok. Any way to check where the fuses plug into to?
Any other ideas?
Old Jan 6, 2008 | 07:09 PM
David1's Avatar
I see in haynes that both fuses are in the interior fuse box - radio and hvac - #1 I would check to see if anything else controlled by that fuse box is acting up - maybe a ground is bad - it's in a tough spot for tracing where the wires go, so that's why I asked if anything else is acting up as it will be a job.
The only common item between the radio and the ac is 1st the fuse box
97slow
Oct 30, 2013 08:57 AM
daysu47
Sep 17, 2008 03:03 PM
mark2patterson
Mar 18, 2008 08:40 PM
castortroy
Nov 11, 2007 11:37 AM
castortroy
Oct 23, 2007 12:52 PM
