94 sc2 5spd need clutch help
Old Jun 19, 2008 | 10:40 PM
MyfreeSC2's Avatar
How do i bleed the hydraulic clutch system on this car?
Old Jun 20, 2008 | 09:55 AM
TheEngineer's Avatar
There should be a bleeder valve in the system. Usually its near the slave cylinder. Once you find it, you need someone else that can pump the clutch pedal for you. Here are the simple steps i usually use in any car.
1.Fill the clutch fluid resevior
2. Very slowly have someone push the clutch pedal down till it bottoms out (leaving the bleeder valve closed). Hold the clutch pedal on the floor.
3. Loosen the bleeder valve to let it release some air/fluid. Then retighten.
4. Release the clutch pedal.
**Repeat steps 2-4 (about 5 times or until you notice that it is just clear brake fluid comming from the bleeder and the clutch pedal is stiff)
5. re-Fill fluid resevior
notched306
Jun 8, 2013 07:52 AM
brob81
Jul 9, 2008 10:48 PM
2000saturnsl2
Mar 16, 2008 04:28 PM
HeatherP00
Nov 8, 2005 03:35 PM
Lane85032
Aug 12, 2005 08:34 AM
