91 SL1 high idle?
Old Aug 7, 2011 | 07:59 AM
kelliott's Avatar
Unhappy 91 SL1 high idle?
i bought a 91 sl1 from a guy who started it with the throttle body off and it caught fire for about thirty seconds. no serious damage but the wires surrounding had the coating burnt off and the vacuum lines were all gone. i replaced the vacuum lines but wasn't sure if i had them ran from port to port the correct way. it will start right up and rev to 2000 rpm and as soon as it starts to drop it dies. i have a idle air control motor on order to see if thats the problem but i would like a second opinion
Old Aug 7, 2011 | 02:28 PM
Did you replace the wires that got stripped? You dont mention that you did.
Old Aug 8, 2011 | 09:35 AM
JoshKava's Avatar
if the previous owner was fooling with it thats means there was a issue prior to the fire.... I would search online and find a diagram of the vacuum system and double check your work, let us know what happens when you get your new part on , you may be on the right track there.
Old Aug 8, 2011 | 03:11 PM
scotterichmond's Avatar
I am not too sure why you would replace a part, when you don't know if all else is "right"
Old Aug 8, 2011 | 10:07 PM
fire, toasted vac lines and melted wire insulation do not strike me as "minor".
The 91-93 S series chilton book has vac diagrams I do believe
Old Aug 9, 2011 | 12:29 AM
Arn't the vacuum line diagrams for the car on the emission lable on the radiator support cross member?
Also isn't the SL1 some what prone to a plastic part breaking off on the intake manifold causing a huge vacuum leak and this type of problem?
And of course any automotive fire that burns stuff is hard to relate to as minor 'specially if cause by some one trying to start the car with the throttle body removed.
To me that sounds a bit like trying to float a boat by poking a hole in the bottom.
Old Aug 9, 2011 | 09:28 PM
damn I wish we had video
rdrunnr
Sep 6, 2016 09:53 AM
cloudsplitter8
Aug 24, 2012 07:47 PM
helistructor
Nov 14, 2010 07:16 PM
blind527
Nov 22, 2006 09:33 PM
