2002 SL2 Sedan Won't Start
Old Jul 19, 2009 | 08:29 PM
vslap's Avatar
Default 2002 SL2 Sedan Won't Start
Battery is fine...Lights work, radio works etc... I turn the key and get a clicking noise only...any ideas as to what is wrong?
Old Jul 19, 2009 | 10:25 PM
1)Check battery cables for corrosion and good connection positive at battery and starter, negative at battery and ground connection to frame.
2)Have battery load tested
If these check out ok, probably starter solenoid. whack it with a hammer and see if car starts. If it does, confirms theory.
Starter solenoid is integral to starter---can replace separately but recommend new starter.
Old Jul 19, 2009 | 11:09 PM
vslap's Avatar
Thanks... I'll give it a try in the morning
Old Jul 20, 2009 | 09:25 AM
vslap's Avatar
It was just a dead battery. Put a new one in and it started right up. Thanks for the help!
Old Jul 20, 2009 | 08:33 PM
No problem. Glad it was a quick fix
tikidude
Aug 30, 2014 05:04 PM
daved
Jul 28, 2010 02:57 PM
resin14
Feb 14, 2010 05:32 PM
Kzaharris
Dec 12, 2009 06:34 AM
wickedhx
Apr 21, 2009 09:28 AM
