2001 SL1, failed smog test: loose vacuum hose the cause?
Old Jul 31, 2024 | 12:52 AM
d0ugparker's Avatar
Question 2001 SL1, failed smog test: loose vacuum hose the cause?
2001 Saturn SL1, SOHC, 222,000 miles, getting a P0410 error code.
I found a loose vacuum hose to the top of the intake manifold. Here's a photo showing the hose location and the hose that was disconnected.
The rear-most hose is the hose that had become disconnected.
(I'm looking for a way to halve the size of the picture, but I can't find one.)
Can that hose disconnected at that highlighted cause P0410 errors?
Old Jul 31, 2024 | 11:34 PM
Greg97SW2's Avatar
That code is for the air injection system and I believe the small vacuum hose in front goes to the control valve for the injection system. So perhaps with the rear one disconnected there is enough of a vacuum loose to affect the control valve. Did you clear the code and see if it returns after connecting the hose?
Old Aug 1, 2024 | 10:57 AM
grcauto8453's Avatar
Hook it up and clear the code. Does it come back?
Old Aug 2, 2024 | 07:35 AM
With that many miles on it, the hose may have a split in it. Check both ends and trim it if you have enough slack, then reattach it.
Saturn2Uranus
May 27, 2024 08:23 PM
mikelife85
May 19, 2014 01:45 PM
dondellison
Oct 15, 2013 09:58 PM
maidel
Sep 26, 2013 11:16 PM
cordytess
Aug 27, 2009 07:52 AM
