2000 SL2 Power Problem
Old Jun 15, 2010 | 05:00 PM
ryan777's Avatar
Default 2000 SL2 Power Problem
I changed my starter, drove about 20 minutes, got out and tried to lock the doors via remote, no power. I tried to start the car and I had no power coming through, car acted like there was no battery in it. I took the battery off, left it for a few days, then put the battery back on. Started perfect. Then I drove it and was seeing the gauge cluster flicker, getting dim and bright when I would drop into neutral. Headlight flicker and everything.
Today I was gonna get the alternator tested but I still have no power. What is wrong with it? It did not do this before the new starter.
Another new problem is this, if I get the rpm's sitting at any number, the rpms will just rise, no movement of my foot.
Any help would be good. I'm this close to taking it to the dealer or setting it ablaze.
Old Jun 15, 2010 | 11:47 PM
Replace both main battery cables, and ensure they have clean/tight connections both at the battery, and on the other end as well .....
Old Jun 16, 2010 | 07:32 AM
hoseppi's Avatar
Also, check to make sure that you reattached the wire that goes from the starter to the alternator.
Old Jun 18, 2010 | 01:03 PM
bad battery terminals can also corrode right inside where the terminals come through, causing intermittent "access" to the charge in the battery. I've actually had one fall off while trying to tighten the pos terminal wire
tfg11199
Jul 27, 2010 09:45 AM
Alex H.
Aug 29, 2009 10:18 PM
Mike1288
Feb 15, 2009 02:10 PM
dman545
May 8, 2007 12:38 AM
Rare96Formula
Jan 24, 2007 03:01 AM
