1999 SL1 door jamb switch for dome light?
Old Apr 5, 2014 | 05:50 PM
sldood's Avatar
Default 1999 SL1 door jamb switch for dome light?
Need a door jamb switch for driver's side door so dome light will come on when door opens.
Tried a junkyard one today - it was a dud, unless there's a wire problem? The passenger side works fine- open the door, light comes on. I took pass. side one from junkyard thinking it would be less beat, but no luck. It seemed to plug on the connector fine.
The orig. GM part # 21023335 is NLA and it seems like no generic/Chinese/knockoff version available on ebay, etc.
Any advice? Thanks.
Old Apr 6, 2014 | 10:37 AM
keith's Avatar
Get an ohmmeter and check the switch. If you don't have an ohmmeter, see if any of your friends do. You can buy one at a Harbor Freight Tool store for a couple of bucks. You can get one from just about any autoparts store, hardware store or discount store (walmart) for less than $10.
These will actually be multimeters so you can check for the proper voltage on the pins of the connector that the switch plugs into.
Tobykanobe
Aug 11, 2009 11:17 PM
canarycary
Jan 12, 2009 05:28 PM
bjw109
Mar 3, 2008 06:49 PM
jimmyg
Oct 2, 2007 09:28 PM
gadawgfan
Feb 25, 2007 10:31 PM
