1999 saturn sw2 with 96 97 motor questions
Old Mar 26, 2025 | 01:24 PM
arenzsteven's Avatar
Default 1999 saturn sw2 with 96 97 motor questions
ok so i bought a 99 s series wagon apologies its not a sedan but theres no forum section for it.
anyways i put a 96-97 motor in it with a 94 valve cover. my question is which valve cover gasket should i use.
a- https://www.autozone.com/external-en...e+cover+gasket
option b- https://www.autozone.com/external-en...e+cover+gasket
Old Mar 26, 2025 | 09:33 PM
Everything below is for the DOHC only
94 valve cover as in aluminum?
I would say use the 94 valve cover gasket or it will not necessarily fit in the groove of the valve cover from 94.
It's a custom-shaped seal up against a flat surface. Shouldn't be a problem and I know people used to run the aluminum valve covers on the second generation S car engines.
You may find that the 94 cover has through holes to attach additional bolts that the 97 plastic cover does not. Use this to your advantage and get a few extra bolts.
Having driven DOHC S cars since '92, the aluminum covers have more attachment points, but as long as you have clean mating surfaces, follow the tightening order and do not over torque things, they both work just as well.
cuetip
Nov 16, 2024 10:49 PM
Bud
May 2, 2024 09:17 AM
zacsdad
Mar 26, 2010 04:24 PM
Michael F
Oct 20, 2009 08:26 PM
jntroisi
Jul 9, 2009 04:29 PM
