1999 saturn sl2 ignition problems
Old Nov 10, 2009 | 07:44 AM
bcantara54's Avatar
Default 1999 saturn sl2 ignition problems
I went to start my car this morning and the key wouldnt move it was stuck in accessory the key wont come out the car is in park and the steering wheel isn't locked ?
Old Nov 10, 2009 | 08:36 AM
blakesdad's Avatar
Make sure the shifter is pushed as close towards the radio as it can. My 99 sl2 sometimes gets the stuck key problem also. As for it not starting whats the issue there?
bcantara54's Avatar
i cant turn the key at all
Old Nov 10, 2009 | 08:42 AM
blakesdad's Avatar
Try to put the shifter in drive then back into park. Make sure the shifter is all the way towards the radio push on it a little while trying to remove the key.
Old Nov 10, 2009 | 08:47 AM
Bad key, have a NEW one cut by the dealer DoNot have a key ground to match the worn one.
Bad ignition have a new one rekeyed by the dealer
Old Nov 10, 2009 | 08:52 AM
bcantara54's Avatar
I tried it and nothing Im starting to think its a bad ignition switch
Old Nov 10, 2009 | 08:54 AM
blakesdad's Avatar
Sorry I couldnt help. I would go with Rijon in this direction.
Old Nov 10, 2009 | 08:58 AM
bcantara54's Avatar
do you know of any way to get the key out do saturn have a release button?
Old Nov 10, 2009 | 09:03 AM
blakesdad's Avatar
I'm not sure about that. I would contact your local dealership for that info.
Old Nov 10, 2009 | 10:51 AM
bcantara54's Avatar
I just wish I could some how get the key out because I think its just a bad key
