How on earth did I forget about the cat con heat shield that comes as part of the cat and is held on by industrial strength chicken wire?
BAD Derf BAD Derf |
I'm just trying to think outside of the box, or in this case the engine compartment. Rattles can be mysterious.
Another thing that rattles on my Saturn is the rod that holds the hood up. The plastic thing that holds the rod down when not in use is broken so it rattles at idle between the cross brace and the hood.
Originally Posted by Vlocybug
(Post 55216)
I'm planning to remove the cover on the passenger side front door at some point to tighten the window handle (it is obviously loose and has been for years *Not the cause of the rattle though *).
| All times are GMT -5. The time now is 08:42 AM. |
