1999 Saturn heater not hot
Old Nov 26, 2023 | 12:16 PM
radio83's Avatar
I cant cancel the order it shipped. Looking around, i'm not sure if evey one using Motorad housings , but almost every thermostat housing i'm seeing as motorad . I will order Stant thermostat. Not sure how the remove old thermostat and put new thermostat in the old housing.
Old Nov 26, 2023 | 04:54 PM
I wonder if Motorad is the manufacturer of the thermostat housing and Gates installs one of their thermostats. It says Motorad and Germany on the housing.
Old Nov 26, 2023 | 04:56 PM
They both use exactly the same picture though.
Old Nov 26, 2023 | 05:20 PM
radio83's Avatar
That what i'm thinking. Housing Motorad and Gates installs one of their thermostats. I looked around on auto zone, napa and O'Reilly's. All there pics show housing labeled with Motorad made in Germany as well
Old Nov 26, 2023 | 07:24 PM
If you search the internet, you will find many have suffered the same fate as myself. I don't expect you to believe one experience from one person defines it as a dud. I found out after I purchased mine and installed it.
Old Nov 27, 2023 | 08:15 AM
I'd suggest flushing and back flushing the heater core too, but that's just me. BUT, if you don't know how to replace the thermostat and housing, you'd best not attempt that either. Sounds like you need to take it to a REPUTABLE shop if you know of one. Here's a how to video on the thermostat replacement.
Old Dec 2, 2023 | 08:26 PM
radio83's Avatar
The Stant thermostats, will they fit in the current housing where old thermostat come out of??
Old Dec 3, 2023 | 08:48 AM
Depends what's there.
I think the OEM stants from Germany fit the OEM housings. (Duh)
I think the newer stants are bigger.
You'll have to research this on Saturnfans.com. The answer is in there
Old Dec 8, 2023 | 05:47 PM
radio83's Avatar
Just thought i update. Had a Stant thermostat put in and put new Engine temperature senor. Engine temp is shown in the pic and heater blowing hot air once again.
Old Dec 8, 2023 | 09:36 PM
Thanks for stopping back. Most don't bother. Did it come w a housing, fit the existing? Would be nice to know.
