1996 saturn sl1
Old Nov 8, 2010 | 10:17 AM
96sc1996's Avatar
Default 1996 saturn sl1
I have a couple of problems
I keep having a a p0401 egr flow insufficent detected.... I replaced and cleaned the egr valve and sensor. the tach shows it idles low.. around 400 but when i hook up a scan tool it seems to be idling ok... the car vibrates until it is warm.
Now i am getting the same code and p1640 quad driver module malfunction
and p1641 quad driver module malfunction and a p1620 low coolant when I dont have low coolant...although i do smell coolant when i put my heat on.
ANY HELP IS APPRECIATED!!
Old Nov 8, 2010 | 10:05 PM
don' t think an s car can idle that low (what did the scanner say the rpms were?
Quad driver faults are almost never the quad driver but instead something monitored by the circuit -- which is a bunch of stuff
Based on the EGR code, I'll venture to guess it is an issue with the EGR solenoid not modulating the EGR position correctly since you've already cleaned the EGR
Old Nov 10, 2010 | 12:01 PM
96sc1996's Avatar
i have replaced the egr sensor when i cleaned it....
Old Nov 10, 2010 | 06:47 PM
a solenoid is a device not unlike a switch.
don't know what you mean by egr sensor unless you mean solenoid
Also you indicated you "replaced and cleaned the egr valve and sensor".
Which is it? Cleaned or replaced?
Old Jun 16, 2011 | 02:31 PM
96sc1996's Avatar
ive cleaned the old one and then i replaced it and i still have the code i cleaned out all the ports well when i changed the motor.
Toberman
Jun 5, 2008 09:32 AM
Uncle Phil
Feb 5, 2008 07:04 PM
NvMySi
Oct 9, 2007 03:13 PM
jumpshotjonny
Apr 11, 2007 10:07 PM
2001s4ny
Jan 18, 2007 04:08 AM
