1995 SOHC Vlave Cover Bolt Head Size
Old May 12, 2008 | 09:23 AM
trysten's Avatar
I need to replace my Valve Cover gasket on my 1995 SL. Does anyone know the size of the point driver needed for the bolts? I am going to have to beg/borrow/buy the tool and just need to know what to look for. Thanks in advance for your help!
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old May 12, 2008 | 11:19 AM
Low Saturn's Avatar
I think its a T-25 or T-30. Just pick up a set of Tork bits from Sears or a local store that sells tools. There are a few othertorx bolts on the car, so eventually you'll need the other sizes.
And make sure you are using the proper gasket and tightening the bolts to the proper torque. And if you have a DOHC engine, in the proper sequence.
Old May 12, 2008 | 12:49 PM
TheEngineer's Avatar
Huh? isnt the valve cover bolts just sockets. I did it last year so im not really 100%...but they arnt anything special...unless your talking about the cylinder head bolts...in that case you do need the special size. But valve cover bolts arent anything special
Old May 12, 2008 | 01:07 PM
Low Saturn's Avatar
1991-2002 SOHC valve covers are held on by two big Torx bolts.
1991-1995 DOHC aluminum covers are held in place by torx fasteners while 1996-2002 composite covers use a 10mm bolt.
Old May 12, 2008 | 06:43 PM
ah i see. I have a 96 so i thought it would be the same as the 95. I am corrected
makayafox
Oct 3, 2013 07:24 AM
KCKIM
Nov 28, 2008 08:09 AM
kia 48
Engine & Internal
Jul 7, 2008 09:11 AM
trysten
Jun 16, 2008 10:47 AM
mjdjlh2000
Mar 23, 2006 01:26 PM
