| keith |
Sep 1, 2013 11:44 AM |
The reason you can't find timing marks to use a timing light on is because there aren't any. You can put your timing light away.
To check the timing, jack up the passenger side front wheel, support the car with a jack stand and remove the tire and the removable inner fender cover. Caution, there is a molded fastener on the inner fender cover that is not visible. After removing the visible fasteners and sliding tab A out of slot A (you will see what I am talking about when you get under there), gently tug around the bottom edge of the inner fender until you find the hidden fastener. Then use a flat tool to pry the inner fender from the frame rail at this point.
Added Note: You might get by with just removing tab A from slot A and bending the inner fender cover out of the way. This is located right behind the strut and just in front of the crank pulley.
On the front of the timing chain cover, there is a dimple at the 12 o'clock position. There is another dimple on the front of the crank pulley. Turn the crankshaft until the two marks line up at the 12 o'clock position.
Remove the valve cover. On the camshaft timing gear, to the right side just above the cover rail of the head, FRT should be be visible. It will be at about the 2 o'clock position on the cam gear, level with and just above the cover rail. If it is there, the timing is correct. If you don't see it, turn the crank 360 degrees and check again.
When you get through doing this and all is well, then I suggest that you get an old, but known good, spark plug. Close the gap to about .025", then one at a time, remove a spark plug wire, insert this test plug, then lay the plug on something metal, but in an area visible through the windshield and crank the engine and look for a visible spark. Do this at night so you can see it better.
I think you will find that one coil is producing a good spark at both wires and one isn't producing any spark at either wire. Your engine will run on three cylinders, badly of course, but it will not run on two cylinders, though it might catch for a second occasionally.
