1994 Saturn SL, turning over, no start.
Old Jun 13, 2013 | 10:48 PM
Merkle85's Avatar
Default 1994 Saturn SL, turning over, no start.
Car:
1994 Saturn SL 1.9L SOHC
Tonight I replaced the starter thinking that was the issue and it wasn't. The car is turning over but is just spinning. There is fuel coming from the TBI so that's not the issue. I checked all the fuses, they're all fine. I replaced the plugs and wires today in case it was a spark issue. So now I'm thinking it's the ignition coils. Is there any way to test them before I goto scavenging at the junk yard for replacements? What other things should I check? The engine just spins smoothly, it doesn't make a regular cranking noise, it's very odd. Just whiiiiiiir not whir-whir-whir. If that makes sense.
Old Jun 14, 2013 | 07:24 AM
It might be a defective ECTS. Electronic coolant temperature sensor. It's a known issue with the Saturn 1.9 engines and can cause all kinds of problems. DON'T get one from your local Autozone or Advance, etc. You really need to find a GM dealership that still sells Saturn parts and get it there, along with the pigtail. Now, I'm no mechanic and am not saying this is your problem, but it could be. Check for spark at the plugs simply by removing one, attach the plug wire back on it and ground it somewhere on the engine where you can see it and have someone crank the engine. If it sparks, you'll see it and be able to eliminate that as a cause very quickly. Your next step would be a compression test.
Old Jun 14, 2013 | 09:32 AM
Oh dear --
I think Rube may have hit the key here -- a compression test is definitely next on the list. I'm almost afraid to read your results ....
Old Jun 14, 2013 | 01:36 PM
Merkle85's Avatar
Right on, a compression test is never a bad idea on a second-hand car that has been bought in such bad shape. Is there a guide for replacing the coolant temperature sensor?
Old Jun 14, 2013 | 05:19 PM
Straight forward swap-out of defective part with new OEM device (get the electrical connector replaced too) About $40.00 for parts, and an hour's time for you.
That said, I'd run the compression test before doing anything else .... just my opinion
Old Jun 14, 2013 | 07:52 PM
Merkle85's Avatar
I'll see if I can rent a compression gauge from Autozone tomorrow.
Old Jun 15, 2013 | 01:21 PM
Merkle85's Avatar
Bad news, she's dead. Tried cranking it with the oil cap off and there is no valve movement whatsoever.
Old Jun 15, 2013 | 02:29 PM
Broken timing chain, at a guess ... that's what I was afraid of when you said it sounded "different" when ya tried to crank it up.
Gonna have to open this one up, and assess the damage ... sorry about that. Might start looking around for a replacement engine at a wrecking yard.
Old Jun 15, 2013 | 03:05 PM
Yep, if the valves ain't moving, the cam ain't turning. It may be salvageable. I'd' open it up and check it out if it were mine, before condemning the engine.
Old Jun 16, 2013 | 01:45 PM
Merkle85's Avatar
If I had a garage and the car was in good shape overall that would be one thing. But I don't and the car still has a slew of other problems. It looks like I would have to drop the transmission to access the timing chain, and there could be valve and piston damage. The transmission is already shifting odd so we're going to cut our losses and buy a new (used) car and haul this one off.
I appreciate the input guys. Who knows, it may be another Saturn.
