02 saturn sl2 automatic
I been having a problem with the egr valve. i have cleaned it out and the valve is working, but sometime after the engine gets warm it starts to stutter going down the road at a constant speed. And it sometimes also stalls when pulling out of a parking spot in reverse. anyone know of a way to help me out?
i have left the egr valve off and started the vehicle so it runs at 3 in a half thousand rpms to blow out the carbon in the passage and it helped a lil but then it started acting up again after a couple days. i also have a 95 saturn sl1 5 speed and i did that once on it and it helped it from having a rough idle. it just this 02 have been a hassle to get it to run smoothly so i could get someone to come look at it so i can get it sold.
I haven't replaced the egr valve but recently the transmission as been acting a little messed up it seems like it slipping and it may have a bit too much fluid in the transmission cause it has bubbles on the stick wen i check the fluid. Would anyone have a reason that may help my problems? I have switched and egr off of my older 95 saturn on the 02 saturn not sure if it was working better, but it still threw a code of po405 and the transmission threw a code of po733 Gear 3 incorrect ratio
lyubovny
Sep 5, 2009 10:13 PM
anti-rice 01sl2
Apr 19, 2008 11:01 PM
