2007 Saturn Outlook 2 cut wires...any idea what it leads to can't find the other end located near brake booster looks as if the wires were not secured properly and was touching the steel and burnt but there's not trace to the other end. Can anyone identify what plugs are these. Obd codes are intake camshaft system position I'm no mechanic but I'm trying my best to at least identify the plug so I can resolve 2 plugs cut someone wrapped electric tape to prevent further damage until found
Welcome to the forum, please check in at the new member area. Then continue with your posts, we will need more background on your car. Is this a recent purchase and if so what works and what does not. Please post codes by P****, we can help diagnose those problems. Those are harness connectors with multiple wires in each connector. Where does the harness go to? Is it part of the main engine harness or does it disappear through the firewall? It also my plug into the bottom of an under-hood fuse panel.
