Need Advice
Perform a very thorough mechanical inspection before you start spending money on the vehicle. It may have rusted frame issues, electrical issues from critters chewing through the wiring, leaking seals from drying out..... Check the compression to get an overall idea of what you are dealing with.
If you totally don't care how long it lasts nor if you get stranded when it goes, you can probably find the glass at a junkyard.
. You also want to pull the carpet up first and see if and how bad the mold issue is. Wear a mask because if it is black mold, it can be extremely dangerous and you do not want to be inhaling the spores
Compression Check
kelkay
07-19-2008 04:46 PM
