Hard accel = no speed & high engine revs
Old Apr 24, 2021 | 02:17 AM
Dukefam19's Avatar
Default Hard accel = no speed & high engine revs
2005 L300 :
starts, runs, idles all just fine. No shaking or hard shifting or anything but when I hard accelerate the car stops gaining speed and the engine just revs high. But if I remove my foot from the gas and reapply everything is back to normal. What should I be looking at with said issue?
Old Apr 24, 2021 | 06:36 AM
Deleted your other post.
No double posting, please.
Thanks
Old Apr 24, 2021 | 06:40 AM
Dukefam19's Avatar
Default Oops
My apologies, I was unsure which one to post on and had no idea it was something against the rules. I will be sure not to again. Thank you for the heads up.
Old Apr 24, 2021 | 08:05 AM
DropDead's Avatar
Any pending codes for solenoid maybe? When was the last time the trans was serviced?
No harm no foulit's all good
Old Apr 24, 2021 | 08:20 AM
Dukefam19's Avatar
No codes, no check engine. Its doesn't idle high noticeably n e way. It drives smooth jut the issue only is at the time of quick acceleration but during this issue theres no shaking or sputtering or funny noises just the rpm rev of the motor which sounds normal.
Old Apr 24, 2021 | 09:43 AM
Does this happen on level ground or when you're going uphill? I'm not a mechanic, but it sounds to me like either it's transmission slipping or a catalytic converter that's clogging up on you. How many miles on it?
Old Apr 24, 2021 | 10:02 AM
Does it flare in all forward gears? Or maybe just second. Probably needs a transmission professional to properly diagnose.
Old Apr 25, 2021 | 09:02 PM
Dukefam19's Avatar
Well ya know I honestly didn't try to see if it was in every gear good idea I just know the straight away here instead 55 mph and cruising at that speed is when I would check it out and floor it. I'll have to do some research tomorrow and get back to you on this thank you.
Old Apr 26, 2021 | 08:38 AM
It sounds like the car downshifts and will not accelerate due to a restricted fuel filter. Try that first.
