cooling fan won’’t stop?
Old Sep 5, 2008 | 04:02 PM
saturnl300's Avatar
I have a 02 L300. the cooling fan stays on. the only way it stops is when I pull the 30 amp fuse out of cooling fan number 1. I try to put it back in the next day & the fan starts again. Help
Christian
Old Sep 6, 2008 | 12:31 AM
saturnl300 -
From what you describe, I would suspect that the radiator temperature sensor has failed. It allows the fan to operate after the vehicle has been turned off, to cool down the engine / radiator that has been run hard, or on a very hot day. To verify the problem, disconnect the sensor to make sure the fan stops.
DO NOT DRIVE VEHICLE WITH THE SENSOR DISCONNECTED BECAUSE YOU COULD OVERHEAT
hollywood32401
Dec 14, 2008 08:50 PM
robot
Jun 25, 2008 07:21 AM
mfunk49
Jan 27, 2007 10:13 AM
vetteguy
Aug 20, 2006 09:41 AM
one day
Jan 20, 2006 02:58 AM
