Water on passanger side floor board.
Old May 29, 2019 | 02:00 PM
Nobel Hansen's Avatar
Default Water on passanger side floor board.
I just recently got a 2001 L200. We discovered we get water on the right floor board when it rains. The seals are good on the door. It looks like it runs down the door seal to were the hinges are and gets in. Is there a drain somewhere over there that is plugged?
Old May 29, 2019 | 09:42 PM
Do you have a sunroof?
Old May 30, 2019 | 03:15 AM
Default No sunroof
Nope no sunroof
Old May 30, 2019 | 10:11 AM
There are drains on the bottoms of the rocker panels. My car got wet from water in the right side A pillar filling up and leaking inside. I found it by removing the plastic trim and hosing the car. The drains were partially plugged and cleaning them did not solve the problem. Down low on the pillar there was a factory sticker covering a factory hole used in manufacturing. Only it had slid down uncovering the hole, I made a new “ sticker “ with gorilla tape and solved the problem.
Andy
Old May 30, 2019 | 11:06 AM
Default C
Andy
ldldulu
Could you please take a pic for I could get a idea where to look
Old May 30, 2019 | 11:39 PM
It is behind the plastic trim piece that has the fuse panel access door. I am not going to take my car apart for a picture, sorry. Your car get wet sitting in the rain not driving in the rain, is that correct? If your car gets wet driving in the rain it may be sealant failure in the wheel well area. When my car leaked it got wet in front first then the water ran to the rear carpet. There is no drain for the carpet area.
Old May 31, 2019 | 12:26 PM
Default When its parked
Yeah it only gets wet when its parked and it has rained. No wasnt wanting you to take yours apart, just wasnt sure where to look for what plastic.
Old May 31, 2019 | 08:02 PM
I have a parts car partway disassembled, I will take some pictures on Sunday
Old Jun 1, 2019 | 01:23 PM
Thank you.
Old Jul 25, 2019 | 08:07 PM
Richard Davis's Avatar
Default plugs
Of course there are plugs, both in the rockers and in the floor but of course it only matters if you are going to pull out the carpets for drying etc, (as maybe you should do) or just get rid of the water. In that case I recommend a cup. Or a wet vacuum. In the climate where I live in, mold would never be a problem, especially in the summer. Very dry. But if your rig is supposed to be date-worthy, even by rednecky standards, it might need the full carpet treatment. (They will refuse to get in it.)
As to the seals what else can you do but replace them? See if you can get some good seals out at a junkyard or else buy new ones.
rickdrat
May 6, 2018 10:18 PM
stephen cupp
Nov 21, 2015 07:01 PM
webbj8150
Jun 22, 2015 09:02 PM
Possum
Mar 18, 2015 10:40 AM
deborahallyson
Feb 8, 2009 12:54 PM
