sl2 door hinge separation
Old Apr 26, 2011 | 06:43 PM
terrabull1's Avatar
Default sl2 door hinge separation
Hello, new to Saturns and this forum. I have a 2000 Sl2 V6 and have owned it for about a month. Shortly after we purchased it we noticed that the drivers door had to be lifted to engage the latch. My first thought was the pins are worn but on further inspection I found that the lower body side of the door hinge has actually started to separate from the pillar. Not sure if these are welded on or if they use a bonding agent. If anyone has had this problem or knows how this could be repaired it would be greatly appreciated. thanks
Old Apr 26, 2011 | 07:01 PM
S series cars all came with 4 cyl engines so you do not have a V6 unless a very ambitious previous owner dropped alot of coin and alot of time.
Notwithstanding your description -- If it IS an s-series -- are you sure the problem is not being caused by the lower portion of the inner door panel contacting the bottom of the door opening? The inner connectors for the panels sometimes pop out and the panel will sag just enough to make door closing a chore...
Old Apr 26, 2011 | 08:17 PM
terrabull1's Avatar
definately v6(3.0) and the hinge is separating from the a pillar. got pics but cant figure out how to post them
Old Apr 26, 2011 | 08:39 PM
terrabull1's Avatar
heres some pics. you can see the white line where the hinge is separating and when you open the door all the way the whole pillar flexes and the gap gets bigger.
Attached Thumbnails sl2 door hinge separation-img_1115.jpg   sl2 door hinge separation-img_1113.jpg
Old Apr 26, 2011 | 09:13 PM
That is the LS2, not the SL2, quite the size difference, and very easy to confuse... However from the way the picture looks it appears to be a broken weld.
Old Apr 26, 2011 | 09:49 PM
Also known as the LS200--and not so difficult to confuse when there's a badge that says L200 on the trunk.........
All that now sorted out and thread moved to correct forum.........
Pic=1000 words
I also vote for broken weld (though I am far from an L car expert)
Old Apr 27, 2011 | 12:16 AM
terrabull1's Avatar
Sorry, car was sold to me as a sl2. I`ve never been much of a saturn fan . When my wife needed a car it fit the budget. There are no badges on the trunk but the car hauls ***! Sorry for the confusion
chriSL2
Feb 25, 2009 09:27 AM
satty_kingsb
Apr 22, 2008 06:06 PM
Stapes
Dec 29, 2007 09:55 PM
Mera
Aug 20, 2007 05:41 PM
wagz
29
Jun 2, 2007 11:25 AM
