SERVICE ENGINE SOON light
2003 LW 300 V6....have owned it for 4 years. Every winter we are plagued with this SERVICE ENGINE SOON light that comes on on cold days only (30 deg. or below). I go to Auto Zone and they check it and it says something like "Engine Coolant Differential Temp. abnormal" (May be slightly different wording but it pertains to an engine coolant system differential temp.)
I disconnect the battery for a few minutes, reconnect and the light stays off until the next cold spell. After so many times, this becomes a pain. From all indications, the thermostat works like it should. (Engine never overheats in hot weather and heater warms up normally in cold weather.) Antifreeze in good shape, coolant level good. Has anyone had this problem or does anyone know how to solve it?? All help appreciated! |
ETCS ? Clearing a code does not fix the problem.
Originally Posted by sw2cam
(Post 42560)
ETC ? Clearing a code does not fix the problem.
Get the Pxxx code (get it read again) and post that code here and we'll try to help you sort it out.
(Post 42570)
It does sound like the ETCS.......If it is, get it from the dealer.
Originally Posted by RjION
(Post 42582)
(Post 42570)
from my limited check across the world wide web, this is a thermostat problem. Others report that their radiator cooling fans run constantly when the check engine light comes on with this code. One poster even mentioned that cold weather seemed to aggravate it and cause the code to appear.
Remedy is to replace thermostat based on what I've read. |
Originally Posted by rtread
(Post 42584)
Scuse my ignorance but what would the ETCS be? I'm gonna guess something elecronic and expensive???
ETCS = Engine Coolant Temperature Sensor. |
| All times are GMT -5. The time now is 06:56 AM. |
