P1817 code
Old Mar 16, 2020 | 02:20 PM
Jermaine-Mekesha Davis's Avatar
Default P1817 code
I have a 2001 L300 and my check engine light is on. The code is P1817 transmission position sensor. Where is this sensor located? I can't find anything on it ,
Old Mar 16, 2020 | 05:08 PM
lrbraner's Avatar
My best guess is its what we would call the neutral safety switch.
Although it does much more than that.
It is located on top of the transmission, the shift cable goes to it.
It is visible from under the hood,It may only need adjustment, many have slotted mounting
hole for adjustment.
Old Mar 16, 2020 | 06:45 PM
I’ll see if that’s it. Thanks.
Old Mar 17, 2020 | 12:36 AM
My non guess is that the code definition is
DTC P1817 TFP Valve Position Sw. - Reverse With Drive Ratio
More later
Old Mar 17, 2020 | 05:41 AM
That’s correct, but I can’t find any info on that part or how to fix it.
Old Mar 17, 2020 | 10:44 AM
P1817: Transmission Fluid Pressure Manual Valve Position Switch Reverse with Drive ratio OBD-II Trouble Code
The transmission fluid pressure manual valve position switch/TFP manual valve position switch uses fluid pressure from the manual valve to tell what gear has been selected. If the ECU sees that a drive ratio is been selected, but the TFP manual valve position switch thinks that reverse and has been selected, a P1817 diagnostic trouble code will be stored.
How Serious is the Code?
In order to compensate for the error, the ECU/TCM will command maximum line pressure inside the transmission. This can cause severe damage to the internal components.
Symptoms
Symptoms of a P1817 DTC include:
  • Unusually harsh shifts
  • Check engine light
  • Limp Mode
Causes
  • Failed transmission fluid pressure manual valve position switch/TFP switch
  • Short in the TFP valve position switch wiring harness
  • Poor connection in the TFP valve positions switch circuit
What Repairs Will Fix P1817?
Repair any electrical shorts in the transmission fluid pressure manual valve position sensor circuit
Replace the TFP sensor
https://www.transmissionrepaircostguide.com/p1817/
Old Mar 21, 2020 | 08:42 PM
The fsm says to inspect the wiring at the transmission control module, the transaxle connector and the transmission fluid pressure valve position sensor connector. Look for bent terminals, backed out terminals, damaged terminals, chafed wires, broken wire inside the insulation, moisture or corrosion.
Is this a hard code? This means can you clear it or does it not clear. If you can clear it how long until it comes back?
dabatman99
Aug 13, 2023 07:16 AM
cultsch
Jul 30, 2013 07:02 PM
mikes 1994 z28
Jun 8, 2008 07:16 PM
jason1921
Feb 8, 2008 08:24 PM
ericsyzf
Jan 5, 2007 10:17 AM
