p0300 and p0410, p0300 stayed after 0410 fixed
Old Oct 11, 2019 | 03:27 PM
Brand209's Avatar
Default p0300 and p0410, p0300 stayed after 0410 fixed
it's an 2002 L200 saturn, threw a p0410 code and a p0300 code. replaced the small vacuum lines going to the check and diverter valve which cleared the p0410. now it still has the random misfire code and runs horribly -IF- the hose from the air pump is plugged into the airbox. IF NOT plugged in it will idle properly. I unplugged the check valve and tested it with my volt meter and it is getting current. I've also held my hand on the air pump and it does turn on and pump air. Also thas new spark plugs and the coil pack was tested along with the control module and they didn't fix it. HELP
Old Oct 11, 2019 | 10:45 PM
Not plugged in and the air cleaner hole is plugged or left open? How does it run if the air pump is not running?
Old Oct 12, 2019 | 01:34 AM
Brand209's Avatar
Its open, I've plugged it with my palm and it didn't seem to change anything. When we had it idling the air from that hose was always blowing out. Is there something likely to make it stay on and could that be the issue?
Old Oct 12, 2019 | 10:17 AM
If the check valve on the exhaust side fails you might have EGR at idle and the misfire. I just replaced my check valve because it cracked and created an exhaust leak. The hose is the air inlet for filtered air the the smog pump, there should never be air coming out of the hose.
Old Oct 12, 2019 | 12:22 PM
Brand209's Avatar
are you talking about the valve on the top canister where that connects to the steel tube into the exhaust manifold or the small check valve with the two vacuum hoses mounted on the side of the engine
Old Oct 12, 2019 | 06:47 PM
Brand209's Avatar
yessir, it was the valve. Though it isn't throwing the missfire code. Shes hesitating to shift now in second, and doesn't seem to want to step down for like the passing gear acceleration. No codes though, I'm suggesting they have the transmission serviced. I don't think it's related but could be wrong
Old Oct 12, 2019 | 07:46 PM
It attaches to the steel tube that bolts to the manifold. It takes a 7/8” wrench maybe. It is a one way check valve to only let air into the exhaust. If you take the 3/4” heater hose sized hose off nothing should blow out.
Old Oct 12, 2019 | 07:50 PM
Now it sounds like a throttle position sensor giving you problems. I would clear the codes and take the car for a nice ride so everything can relearn how to drive properly and see what comes back.
Old Oct 13, 2019 | 02:49 PM
Brand209's Avatar
still shifts funky in second, will go up to 4k and not want to shift unless you let off the gas
Old Oct 13, 2019 | 09:09 PM
Will it upshift at light throttle? What seems like transmission problems can be a plugged fuel filter.
