Oil cooler banjo bolt #12992646
Hi Folks,
I actually don't own a Saturn, but a good friend of mine does and I am trying to help him out. I am a car guy and something seems odd about his situation. He took his car to a mechanic that is telling him he needs to replace the oil cooler. As part of this replacement there are two banjo bolts which are GM 12992646. According to the mechanic and a bunch of parts websites this part has been discontinued for quite some time. I have a bunch of questions:
1. Is there any reason to believe the existing bolts would be bad? I believe the concern is that they break off if you try to remove them.
2. Does anyone have a cross reference sheet for GM bolts? I found this part number being used on Open, Vauxhahl and a couple of other makes, but no alternates for the bolt.
3. Any advice on finding a pair of these?
Thanks,
Ed
Thanks,
Ed
Well it is in all likelihood metric. Are any of the threads exposed that you could get a diameter and thread pitch from. Then try to match it up?
They both does not apply to banjo bolts of course. Maybe dropdead can get you some
There was a teenager who used to pump gas in my neighborhood in New Jersey. She was cute, funny and had a wicked sense of humor which is different than funny. When I first met her, all the other customers were yelling something at her and I couldn't understand what it was. I asked her. She said oh that's my nickname. Poof. I asked why. She said because sometimes I'm here and then poof I'm gone.
Sorry that was completely triggered by the thought of dropDead making parts appear from nowhere. Like he has a time portal part machine which is different than a pick-a-pull.
I should go take my meds
Have a fine ish day.
@DropDead , his mechanic is saying that once they are used they get stretched and can't be used again. Does anyone have experience with this? It sounds like BS to me since they are not like head-bolts that get stretched as part of the torquing process... You don't stretch a banjo bolt because they would split, right?
Most flexible brake lines have a banjo fitting on them and they get reused over and over. You just need to put a new copper washer on them. Sounds to me like he needs to find a COMPETENT mechanic. What say you, Billy and Andy?
