L200 high idle problem
Old Jul 21, 2013 | 08:16 PM
Heaton4's Avatar
Default L200 high idle problem
Timing chain jumped on my 2002 L200 and had to replaced the head and timing chain. Now idles at 1800 rpms. Idles constant up and down. Checked with hand held computer got error code P0507(high idle) and P0107(map sensor). Replaced the map sensor and checked the idle air control valve. Appears to be fine. When clearing the codes the engine will idle down and radiator fan will shut down for a second and then idle goes back up to 1800. I'm stumped. Does it need to be reset with the computer? Is this something I can do or does it need to be done by a dealer?
Old Jul 21, 2013 | 10:22 PM
I'd be looking for a vacuum leak first. Try disconnecting the battery ground cable for five minutes and see it that will reset the computer if you don't find any vacuum leaks. Nothing ventured, nothing gained.
Old Oct 15, 2013 | 09:54 PM
02saturnsl1's Avatar
im leaning toward the vacuum leaks as well also the iac valve can be stuck and did u torque the head and intake manifold to proper specs?
RichKansas
May 14, 2018 12:36 PM
jrg89
Jun 30, 2013 09:34 PM
99 SC1 Silver
Feb 28, 2013 06:47 PM
cloudsplitter8
Aug 24, 2012 07:47 PM
x86guru
Jun 17, 2006 04:24 PM
