L200 Brake noise
Old May 17, 2010 | 10:22 PM
Saturntuner88's Avatar
Default L200 Brake noise
My dad has a 2003 L200 with drum brakes in the rear i did the shoes and drums yesterday, and today he said it started making a clicking noise, i drove and verified it, i pull the right drum apart to find the clip that holds the adjuster screw stuck between the shoe and the adjuster. I fixed it and drove it and it still makes the noise took it all apart again checked it every thing was good. does any one have any ideas as in what the problem could be ?? id appriciate any kind of help i can get
Old May 19, 2010 | 08:49 AM
You did the brakes ........... so you need to see what you have done wrong.
Old May 19, 2010 | 08:22 PM
theres nothing wrong though thats the thing i took both drums off and copied the other side putting it back together some one told me to swap the drums and see if it makes the noise on the other side if so the drums got a high spot and either replace or machine the drum
Old May 20, 2010 | 11:32 AM
Ok then ............. your the SaturnTuner so you know.
Dizzy
Jun 1, 2012 08:07 AM
ruth03
Dec 30, 2010 10:18 AM
dbswayne
May 20, 2007 08:00 AM
jerrardo
Dec 2, 2005 12:28 AM
toby
May 13, 2005 06:51 PM
