l200 2.2L wont stay running
Old Aug 25, 2013 | 06:57 PM
mattl36567's Avatar
Default l200 2.2L wont stay running
just got the car dont know to much about its past. its an 03 L200, the fuel pump blows the 15 amp fuse(going against all electrical rules I installed a 20 amp) which did not blow. the previous owner told me the fuel pump was all that was wrong. now that I have it where I can work on it i found that there are no indicator lights when the key is turned to the start position. with the 20 amp fuse the car will start momenarily then die. when to pull codes and i get a conection error, checked all fuses going to bcm, emc, and pcm. all were good including the one that powers the obd-II connection. I'm thinking that the bcm went out completely. can anyone help me on this one I need another direction to go.
Old Aug 25, 2013 | 10:28 PM
Well, I am not a mechanic, but it seems to me that if the fuse for the fuel pump is popping, then you've got a bad wire going to the fuel pump or it's grounding out for some other reason that I can't think of. I'd start with that. How many miles are on the car and do you know if it's ever been run out of gas more than once or twice. That will kill a fuel pump prematurely.
Old Aug 27, 2013 | 08:19 PM
mattl36567's Avatar
only got the car 3 days ago only paid $500 for it.
Old Aug 27, 2013 | 10:27 PM
Paul b's Avatar
I would check the fuel pump sometimes when they go bad they will draw more current and pop the fuses
Old Aug 28, 2013 | 08:04 AM
mattl36567's Avatar
The fuel pump works with a 20 amp fuse but the car doesn't stay running and there are no indications ie... Fuel level, rpm, temp, mileage. The whole instrument cluster is out. Checked all the fuses to the obd port, bcm,ecu, pcm, gauge panel and they are all good.
Old Aug 28, 2013 | 08:50 AM
Check the BCM/CLUSTER fuse ( 10A ) located in the engine compartment fuse box
Old Aug 28, 2013 | 08:53 AM
Second thought just occurred -- check back on the registry of the car. It might be one from that storm up on the east coast that so many cars were underwater ...
Old Aug 28, 2013 | 08:05 PM
mattl36567's Avatar
its been registered in louisiana since 2008. i know that doesnt mean that it wasnt up there but its at least a chance that it wasnt. Oh, the fuse is good.
Old Sep 1, 2013 | 07:47 PM
mattl36567's Avatar
replaced fuel pump, still no run. it does start for about 3 seconds then dies. gonna replace ignition switch next.
Old Sep 2, 2013 | 08:23 PM
mattl36567's Avatar
replaced the ignition switch today and still a NO GO. looks like I'm gonna have to tow to the dealer a pay for a diagnoses. I can think of better things to spend $90 on!
