L 200 a/c
Old Apr 25, 2015 | 12:08 PM
ClintE's Avatar
Default L 200 a/c
Trying to hit 300k ( 295K ) and this may be the deciding factor if it happens. AC stopping blowing cold. I assumed it was the freon. Installed enough to fix the problem....but still blows slightly cool air. Not enough to matter though. Any ideas?
ClintE
Old Apr 25, 2015 | 12:14 PM
19bonestock88's Avatar
It's probably a compressor... A/C or not, the L series are pretty good cars... 300k was the goal for my old one, but she fell short... The timing chain tensioner failed at 262k...
Old Apr 25, 2015 | 11:56 PM
do a loan a tool from autozone or similar for a set of AC gauges. Read the hi and low side pressures and post them here.
Could be the compressor is worn, per bones. Could be a small leak that is preventing the system from maintaining the desired system pressure differential to cool the air.
Proper pressures are about 200 hi/ 35 low w compressor engaged.
The true "expected" readings depend on ambient air temp.
SLIGHT overpressurizing of the system (at your own risk) may get you to where you need to be w r t cool enough air.
You also may wish to add refrig +dye and then check for leaks with a uv light.
Old May 1, 2015 | 12:13 PM
ClintE,
You've not responded with any updates/feedback regarding your AC prob
Please get your post count up to ten ASAP or your account will be shut down for inactivity. You've not responded with any updates/feedback regarding your AC prob.
chblanx
Jun 7, 2012 05:11 PM
rep
Aug 23, 2010 06:00 PM
fljasin
Jan 23, 2010 10:36 PM
mg4door95
Jun 9, 2008 08:21 AM
mg4door95
Jun 2, 2008 11:10 PM
