Help Please
Old Aug 14, 2024 | 06:39 PM
CarolynaW's Avatar
Default Help Please
Hi everyone. 2003 Saturn L300 sedan
Anytime my battery is connected, my brake lights are blinking. It’s not set the same timer as the hazards or turn signals. It’s also not the full strength, honestly something I could miss if I didn’t know what I was looking for but multiple people have noticed now.
Also, my headlights flash when they are in the “auto” position and the car is off sometimes. It’s random when it happens.
Also, the process of connecting and unconnecting my battery causes my trunk to lock and unlock?
Old Aug 14, 2024 | 08:04 PM
grcauto8453's Avatar
What do you get with the battery hooked up like normal and key off?
Old Aug 14, 2024 | 08:05 PM
CarolynaW's Avatar
the blinking lights
Old Aug 14, 2024 | 08:17 PM
Scan all modules.
Old Aug 14, 2024 | 08:23 PM
CarolynaW's Avatar
Scan all modules.
how do i do that
Old Aug 14, 2024 | 08:54 PM
How long has this been happening? Has the turn signal/headlight switch been replaced recently?
Old Aug 14, 2024 | 09:15 PM
CarolynaW's Avatar
the blinking has happened for weeks. the switch has not been replaced how much does that usually run
Old Aug 14, 2024 | 10:44 PM
Food for thought
Could this possibly be the ambient light sensor that controls the DRLs? Then the brake lights wouldn't be flashing, they would be the running lights turning on and off and on and off along with the high beams of the headlights. The timing would be related to how that light sensor signal is processed. It's probably going rail to rail sending an oscillating signal to the BCM and the result is on off on off on off in a very regular timed pattern
Old Aug 15, 2024 | 07:42 AM
I am away from home and my manuals, however all the lighting except turn signals are BCM controlled. 03+ cars are slightly different from the 00-02 cars. They use the low beams for d.r.l. Very possibly the ambient light sensor/BCM failure on this car. There was a very experienced 03 owner on Saturnfans but I have not seen him here yet.
Old Aug 15, 2024 | 08:08 AM
I'm not a mechanic, but if it was my car, I'd clean the cables and posts on the battery and start looking for a loose ground connection. BUT, like I said, I'm NOT a mechanic.
