A few questions
Hello,
Im going to be purchasing a 2000 saturn LS (im not sure how to tell the difference between the LS , LS1, and LS2) - can you explain that one? It needs a few things done to it.. 1. the intermittent wipers dont work.. the regular wipers work but dont return to the home position when you turn it off so its a fun game of timing it right. 2. the emergency brake cable is snapped because it locked up and couldnt figure how to get it free - dunno if it will lock if i re-install it. 3. the interior door handles are broken? they hang out all the time like the cable is broken? is this a hard fix? and where can i buy parts. i had no luck looking online. 4. the drivers seat cushion is shot or something it sits way deep compared to the passenger seat and pick n pull said its 42 bucks for another one. is this a hard part to put in? sorry for all the questions but i dont know jack about saturns lol. Thanks, Matt |
1. Lemmie look in my book, and I'll get back to you on this.
2. 3. Go to local GM dealer that might have sucked up a closing Saturn dealership 4. Not difficult, but you're gonna need to buy a Manual for you car to proceed |
thanks for the reply, i looked about the wipers alot on my own and the only thing i got replies on was the whole wiper motor needed replacing because it had an intermittent board inside?
also the drivers seat isnt powered so i figured it would just be 4 post bolts to get it out unless saturn does something "cool" the handles i was looking more to get a OEM kit, but i was also looking at pick n pull, if i can get the door apart (goodluck) its 12.99 a side. |
(Post 21843)
2. 3. Go to local GM dealer that might have sucked up a closing Saturn dealership 4. Not difficult, but you're gonna need to buy a Manual for you car to proceed did you find anything? also whats the difference between the LS and LS1? |
Standard equipment like power windows, and if we can take the time to look everything up so can you. |
Matt --
With respect to your intermittant wipers, it's most likely a defective connection in the wiring at the wiper module, however, it could also be a bad control switch in the steering column. I'm assuming you have purchased a Haynes/Chilton manual by now -- break out the meter, and start tracing the circuit ......... |
(Post 22261)
Matt --
| All times are GMT -5. The time now is 07:11 AM. |
