It's not that the door is too far in, but literally that I still need to pull the top hinge bracket to the rear of the car(I accomplished this using a ratchet strap connected to the rear wheel, don't judge) about a quarter inch, and then maybe installing the other two bolts... Basically when I was doing this, I was going on 26 hours without sleep, and had to be at work in six hours, so I really needed to stop and try to sleep a little...
Nonetheless, I fiddled with wiring a little(which was a fun challenge in itself), and got the window to work, and the door lock control to work, but still not there yet... There are like three orange wires(not counting the one with the stripe), two blue ones, two tan ones, two black(ish) ones, and three gray ones, that are confusing to look at... I guessed an orange one and got the door lock switch to fire off the relays, but the driver front door lock has yet to function(the other three move when you use the switch though)... The mirror still doesn't work, and as some bizarre result, neither does the digital HVAC controls(mirror defrost is controlled through HVAC), so I have a ways to go... |
