Dash light control wiring block...
Old Mar 1, 2025 | 04:14 PM
grcauto8453's Avatar
Originally Posted by jim@hitek
grcauto...and what does the instrument panel removal have to do with the well known issue with flickering dash, shift lever, and accessory lights? You didn't read my post well at all so just scroll on by next time someone asks for help.
click in the breadcrumbs and find what you are looking for. Maybe we should come fix it for you. Gezz
Old Mar 27, 2025 | 10:46 AM
lrbraner's Avatar
If you are OK with the dash light brightness not being adjustable,
I found that if you disable the potentiometer, the lights are on full bright with no flickering.
I found this out when i accidently broke one of the contact fingers when trying to clean the potentiometer.
I achieved the same result in another L300 by covering the finger contact area with tape.
Old Mar 27, 2025 | 11:03 AM
Jim@HiTek's Avatar
Thanks for the advice. I may have to do that as my vision problem makes working on/pulling out that junction box difficult. So, yeah, I may have to do that. In the past, back when the brightness control worked, they were just sooooo bright. I might try to find the supply lead to the dash light assembly and put a resistor in series to dim them 40% or so.
Old Mar 27, 2025 | 03:53 PM
Originally Posted by Jim@HiTek
GRCAuto...and what does the instrument panel removal have to do with the well known issue with flickering dash, shift lever, and accessory lights? You didn't read my post well at all so just scroll on by next time someone asks for help.
If you can't click around and find what you want take it somewhere that knows what they are doing. I normally give the manual and expect you to find what you want. Don't expect us to hold your hand.
hoguer054@gmail.com
Dec 20, 2024 07:46 AM
Dinkster
Oct 21, 2024 04:14 PM
Zeutus
Jan 21, 2020 03:26 PM
bmetdave
Aug 4, 2019 05:19 PM
Salvatore Giordano
Sep 17, 2010 07:58 PM
