A/C issue
I have a 2002 L200. The A/C fan will not kick on until about 5 mins after start up. I can feel the A/C vents getting cold, but air does not blow out until about 5 minutes of driving. I have not check under the hood yet. Any ideas on what I should check first? Thanks
I would check the fan relay first then the connector on the fan itself.
Is it the manual control version, or the electronic version of the system? Electronic version has digital temp readout display
It does not have the temperature read out.
Take the time to go to the new member are and give yourself a proper intro. After that fill out your profile and
Open USER CP Then Signature Add First name Location Car info __________________ |
id check the relay
