2003 lw300 cant get to do key relearn light stays on
Old Jun 9, 2021 | 03:38 PM
yosemisteve's Avatar
Default 2003 lw300 cant get to do key relearn light stays on
please help 2003 lw300 replaced pcm replaced bcm now cant get key to relearn how can i bypass to get car going
Old Jun 11, 2021 | 10:29 PM
lrbraner's Avatar
BCM MUST be programmed by dealer to the car.
You cant bypass !!!
Old Jun 12, 2021 | 04:29 AM
Are both new? Both junkyard? Both replaced at the same time?
Old Jan 15, 2026 | 06:49 AM
baddog2b's Avatar
My question is did you try one and then install the other? I had this problem and found that I rushed the procedure and just needed to give the process more time.The instructions I received didn't state the actual time to wait so I had to call the company where I bought the unit from and get more info. I will try and find the exact final instructions they sent that worked and I will post them. Hopefully I can locate them.
Old Jan 15, 2026 | 11:18 PM
The original thread starter never returned with a resolution. This thread is 4 years old with no response. I must have been away working a fire or I would have taken this.
Old Jan 16, 2026 | 08:02 AM
And with that, another indeterminate post closed
yosemisteve
Apr 17, 2021 11:31 PM
yosemisteve
Apr 17, 2021 09:25 PM
curtis rhymes
Jul 25, 2019 02:46 PM
saturnion2003
Jan 16, 2013 05:59 AM
