2002 l300 running terrible throwing codes p0300, p1780 and p0502. I'm lost!
Old Oct 24, 2023 | 08:14 AM
AIRaposo's Avatar
Default 2002 l300 running terrible throwing codes p0300, p1780 and p0502. I'm lost!
I have a 02 l300 with 60k miles two weeks ago I was on the interstate and it out of no where started running rough then shut off and wouldn't start back up. I got it towed to my house and found that the fuel pump was not working so I replaced the pump hoping everything would be ok. After the new pump was installed I started it and it was just running really rough, misfiring and stalling on idle. Since then I have replaced my MAF sensor, coil packs and plugs. I checked my injectors and found one was damaged on the spraying end of it so I replaced that one and cleaned the rest of them. Nothing has made a difference at this point and I don't know what to do/how to determine what is thr cause of the misfiring, the p1780 and p0502 code being thrown. Has anyone experienced something like this that you might have some guidance on how to resolve these issues?
Old Oct 24, 2023 | 08:29 AM
I will start with have you replaced the timing belt? I will look at the codes when I get home tonight. the mileage interval is 100,000 but time is also a factor. I bought my LW300 last year and at 96,000 miles and 20 years I was lucky.
Old Oct 24, 2023 | 08:50 PM
Both P1780 and P0502 are transmission control module codes based on faulty engine control module information.
P1780 is Torque Reduction Signal. The transmission control module received an invalid torque reduction signal from the ECM. The TCM went into self protection mode, went to max line pressure.
P0502 is an unexpected vehicle speed output sensor signal. Speedo will drop out for the key cycle and the transmission will go into self protect mode.
I would look at your engine running problems first.
Old Oct 24, 2023 | 08:53 PM
The timing belt is probably coming apart. That is what I would look at first. The car has four camshafts and if the belt is failing you will have catastrophic engine failure.
Old Oct 28, 2023 | 07:10 PM
AIRaposo's Avatar
So I found a issues with the ground at the battery and I did I few other things what was 3 codes being thrown is now only one and instead of p0300 I'm getting p0302. Yesterday evening I pulled out the injectors and the tip or spray nozzle side of the number 2 cylinder injector was melted. I cleaned the injector up and put a new O ring on it then swapped it with the injector from #4. Put everything together and I'm still getting a misfire still code p0302.
I've never seen an injector being melted around the nozzle like that 🤔
Old Oct 29, 2023 | 11:08 AM
Dude's Avatar
Would suggest timing issues related to timing belt as LW mentioned, could had led to detonation......that will torch anything.
Old Oct 29, 2023 | 09:39 PM
Compression check will confirm the ugly
lrbraner
Jan 21, 2020 10:44 PM
Warlik50
Saturn L300
19
Jan 18, 2019 08:20 AM
mvila0909
Jul 8, 2012 01:07 PM
mcrox007
Jan 12, 2010 02:32 AM
sjwilken
Saturn L300
May 25, 2008 06:26 PM
