2000 Saturn lw1
Old Dec 4, 2025 | 07:38 AM
Cody859's Avatar
Default 2000 Saturn lw1
2000 Saturn lw1. Has very little to no fuel pressure. Fuel pump was recently replaced (before I started working on the car). Won’t start. Gauge reads zero at the fuel rail but some does come out. Testing the connection at the fuel pump I’m only getting 5 volts. Doing a voltage drop test it seems I’m losing 7 volts on the positive side of the circuit. So I ran a wire straight from the battery to the the fuel pump to have direct 12 volts. And still no pressure. I don’t understand help!!! You can hear the fuel pump kick on and also has a new fuel filter. Voltage drop test at the pump also indicates the grounds are good
Old Dec 4, 2025 | 11:17 AM
I suspect that the new fuel pump may have failed due to low voltage.
dj1111
Oct 10, 2025 03:06 PM
dbsaturn
Feb 14, 2025 04:42 PM
Ole_reliable
Sep 26, 2021 07:48 AM
stearns89
Dec 10, 2009 04:37 AM
chuck d.
Oct 29, 2009 09:39 PM
