1996 Beige SL1 Clear Coat is Peeling
Dear Forum,
My 1996 beige SL1 clear coat is peeling -- especially on the roof posts. While this is not unexpected for an 18 year old sedan with 180k miles accustomed to the elements, it saddens me. Shall I sand? If so, can you recommend a paper type and method? Has anyone utilized a "paint pen" kit (near $35 at amazon)?
Thank you,
OSU Beaver Fan
(Looked bad against SC last night
Thank you,
OSU Beaver Fan
If it's begun to peel there, the rest of the car may not be too far behind. I say MAY because things like spoilers were made of different plastic and likely painted via a different process. The clear coat on my 95 and 97 spoilers have been gone for years - probably accelerated by windpath. Don't know about the pillars. Are they even plastic?
I am pretty close to the farthest thing from an expert on bodywork, but here it goes:
1) sanding it will of course remove more clearcoat around the area, I guess this is fine as long as all you are doing is removing loose material.
2) I think using a paint pen filled w clear coat on a roof pillar (vertical surface) will be difficult since it will likely "run" down the pillar unless the stuff is thick and cures really quickly---neither of which sound like properties I'd want in a clear coat material.
I've never used a clearcoat pen. I have used a paint pen on the horizontal portion of a Kia quarterpanel and the paint kept running down out of the grooves I was trying to fill. 'Course the grooves were prob too big for the pen but my point is it ran.
Might work for small spots though
Sorry, that's all I have.
Someone else w body/paint experience pls chime in
alex_0227
Apr 9, 2009 10:15 PM
Racer93
Dec 17, 2008 08:07 PM
