02 Saturn l300 brake lines
Old Sep 3, 2019 | 10:50 PM
Jh1984oh's Avatar
Default 02 Saturn l300 brake lines
Hello have the driver side brake line leaking when brake pedal is pushed looks like it’s coming from somewhere above gas tank am I able to route the brake line anyway I want to avoid dropping the gas tank? Also does that brake line go from abs module back to the caliper or is there one of those t fittings that branch off to both back brakes? Thanks for the help anyone
Old Sep 3, 2019 | 11:03 PM
There are two steel brake lines running to the rear from the abs unit, one for each side. I think they run around the fuel tank not over the top. The driver’s side is a pain due to the exhaust, but I think you can replace the lines without dropping the tank.
Old Sep 3, 2019 | 11:11 PM
Jh1984oh's Avatar
Ok thanks for the reply my next question is will anything be affected if I reroute the brake line and zip tie it to the frame? I know it’ll rust and corrode faster but this car is gonna be scrapped come March so I’m not looking to do a professional job on it
Old Sep 4, 2019 | 08:27 AM
I think you will be fine.
Old Sep 4, 2019 | 08:38 PM
Jh1984oh's Avatar
Ok thanks for the help
Old Sep 5, 2019 | 08:05 AM
I agree with Andy. As long as you get it high enough to clear any road debris (dead animals, mufflers, boards, etc.) you should be just fine.
Old Sep 5, 2019 | 08:45 AM
Jh1984oh's Avatar
Awesome thanks for everyone’s input much appreciated
Old Sep 6, 2019 | 04:29 AM
Jh1984oh's Avatar
One last question is a single flare and bubble flare the same? For some reason a bubble flare tool around my area seems to be hard to find
Old Sep 6, 2019 | 10:25 AM
A single flare is used for low pressure like copper water lines. A bubble flare is a type of double flare, out and in but not pushed back like a double flare. I think you can purchase lines with the correct flares that bend easily and connect them together to get close to the factory length. I have even left a curl in a line to loose some length.
Old Sep 6, 2019 | 05:44 PM
I would NEVER use a single flare on a brake line. Too prone to cracking and leaking and putting everyone's life on the line. I'm not familiar with the "bubble" flare, but generally a brake line carries a double.
