Weak headlight drivers side
Old Mar 29, 2025 | 12:29 PM
IAN4421974's Avatar
Default Weak headlight drivers side
04 Ion - bumped the headlight ever so slightly and now the headlight is dim on the driver side. I found one wire that was corroded (brown) so I cut the ends off and fused it back together plus replaced the bulb and got the same results.
I saw recommendations about cleaning/changing the ground wire from the frame to the transmission but I am awful with electronics.
Thanks!
Old Mar 29, 2025 | 12:46 PM
grcauto8453's Avatar
How EXACTLY did you fix that wire?
Old Mar 30, 2025 | 11:53 PM
IAN4421974's Avatar
I cut the broken wire splice out, cut off the corroded pieces of wire by the splices, stripped and put in a fresh wire splice. Someone had cut all the wires off at some point apparently.
Old Mar 31, 2025 | 12:00 AM
IAN4421974's Avatar
I also swapped the headlight bulb first, then swapped driver and passenger side assemblies getting the same results.
I did not mess with the ground strap from the transmission to the frame but that was going to my next step to clean that.
i looked closely at all the connectors and their pins and there was no signs of corrosion and i blasted them all with some electrical cleaner just to be sure.
Old Mar 31, 2025 | 11:04 AM
Not a proper repair on the wiring.
Not_jdizzle
Dec 31, 2021 02:34 PM
19bonestock88
Jun 6, 2014 01:05 PM
jcrouch75
Jul 14, 2012 09:37 PM
saturnbadgirl
Mar 21, 2009 06:51 PM
iuballer016
Mar 1, 2006 03:55 PM
